3DMark06
Stevemr2t
Had to reinstall this after a harddrive issue, weird thing is I downloaded the file from three different sites and I can't get the program to install. It doesn't do anything when I try to run the install program....
That could be caused by some register issues, I don't really know how to fix that but the reason why you can't install it because there could be some invalid register file of that program in your registry that still remains. If you want to remove those invalid registers use registry editing tool.....
Appears as though some of the download sites might have a bad copy... finally found one that works.
