3dmark06 sli bencharks
precator
I have 2 bfg 7800gts in sli, sli is enabled, and I am only getting a 3300 score. Am I doing something wrong? Shouldn't I be getting a much higher score?
what settings are you running the benchmark at?
sounds like the low score of only 1 7800GT
perhaps there's a hardware conflict? or the rest of your system is poop :(
amd 3500
asus 8n-sli deluxe
1 gig of ram
Sli is enabled in nvidia control panel, I see that is sees both video cards, but in the details tab of 3dmark06 is says gpu 1 out of 1 but i know i have 2.
on the performance and quality page of your drivers, make sure that anti-aliasing and anisotropic filtering is set on "application controlled" if these are turned off, it will kill your score. did you do a clean install of xp after you installed the cards? i got arpund 7500 with 2 7800gt sli. my score was less than half that with aa and aniso off.
I am still getting horrible scores.. other than the benchmarks.. How do i know if my SLI is working? It gave me the popup that SLI is enabled. Basically what I am saying is, i dont care if benchmarks are crappy, i just want to know if both my cards are working in SLI..
How does it perform in actual games?
Under advanced properties on your Nvidia control panel, at the very bottom, make sure that SLI mode is showing as "Auto-select" and not Single GPU mode. Just because you have "enabled" SLI doesn't mean you're actually running it in Dual GPU mode.
noobtech said:
Thats normal for 3dMark06... What is it in 05?
I dont think thats a normal score for a SLI 7800GT system. You seem to have a SLI setup with an opteron... is that your score?
I scored 12K in 05... I forgot what I did in 06.. I thought it was about 3K... but I could be off by a few K. *shrug*
I had a bad score in 06 too, along with very many other A8N32 SLI Deluxe users. I personally think Futuremark mucked up with their compatibility on the 32, because this problem is so widespread.
Yeah, I am sure they will release an updated 06... besides, 06 is almost like 05.
With my old 7800GT's in SLi I scored a 7,165 in 3DMark06.
Now with my 7900GTX's in SLi I scored a 9,016. :D
It could be your CPU score pulling you down.
With the clock speeds and ram size differences... I am surprised you're not getting that much higher with the 7900 GTX.
A 1,851 point jump is pretty friggen nice if you ask me. :confused:
At this point, the 7900GTX's are so powerful that I basically reach the upper limit. 3DMark06 is not GPU limited at this point. I can drastically increase my score by getting my CPU clock higher. When I get my system on water I'll be able to run it at 2.8 or so, which will further increase the score.
You're right... I am just thinking of how big the scores were for me from a TI 4600 to a 6800 Ultra... but those are generations apart. Seeing how you are still using Generation 7 cards... that is a great increase.
My scores in 06 went down after adding a second 7800gtx (auto-select, AFR, SFR) on my A8N32-SLI, but everything else is much better.
With high quality enabled and 8xAF I get ~7900 in 3DMark06 with my 7900GTXs (675) in SLI. Running an athlon FX57@2.9
Is that the x16 chipset?
This is what I get on my XPS 600, no overclocking on cards. Not sure how good this is though...
i used to get around 7200 in 3d06 and iirc that was around average for 7800 gt sli. now i get over 9k with 7900gt sli. i am not using the asus board tho. but i am only getting around 33k in 3d01, which is a lower score than i used to get with a 850xt and a 3500 winny a year or 2 ago. dont put too much stock in it. its only 3dmark.
http://service.futuremark.com/compare?3dm06=187749
i was getting horrible scores also, my problem was that my cpu was overheating, cpu slows itself down when it gets too hot, the solution was i bought a better fan/heatsink (also make sure fan/heatsink sits tight).
I went from ~4500 to 7487 after reinstalling Windows:
7487 3DMarks
SM2.0 3409
SM3.0 3297
CPU 1866
SLI-Auto Select
All else default
1280x1024
I was beginning to think there was an A8N32-SLI/3DMark06 curse, but it was only because I installed the cards at different times on an existing setup (x64). (C&Q is off, no processor driver)
