So I have been running some 3dmark06 tests to see how my computer does and I have experienced some weird results.
I ran it with both the 169.25 and the 169.28 beta drivers.
with single-gpu mode enabled in the nvidia control panel I was scoring around 16,000 which makes a lot of sense. I tried putting the setting to AFR1 and I ran 3dmark06 and got a score of 9,600. Why would my score be cut in half when I run AFR1? I ran AFR2 and got around 15,500-16,000 so there is no problem there either. What could be causing this? There is no reason why AFR1 should nearly cut my score in half...
my specs are as follows:
qx6850 @ 3.33ghz
2gb ram @ 1066 (stock)
(2) 8800 ultras @ stock
vista 32 bit
qx6850 @ 3.33ghz
vista 32 bit
