3dmark03 shutting down
[*****]sc4rf4c3
title says it all...i have a leadtek 6800 128mb. i was able to run it fine before i reformatted about 3 days ago. now when i try and run it, it'll run through the first few test but at the end of the space shooter one (sorry dont remember the name) it just closes....ive got the 61.77 drivers and running windows xp....i dont understand i thought a fresh install would solve problems...not cause them!
anything overclocked? sounds like a stability issue. Any games crashing too?
I'm thinking either the psu is inadaquete or you're overclocked too high. Give us some specs, and run the following:
Prime 95
Memtest86
Had exactly the same issue - have you tried flashing the 6800 bios? This worked for me (though I do have an Ultra), so you may have to dig around for a compatible one..
