Jasonx82 said:That seems good I have a Fx 55 with a 6800ultra and i only get 5225 =(
OrAnGe said:Was trying 3dmark2k5 on my new system ( 3500+ A64 Winchester not oc'd yet. MSI Neo4 platinum. Sapphire x850 XT. Scored 5866 3DMarks. What do you think? Low for the card? ok? whaaaat.
Chaballaman said:u should be able to get higher than that.. i get 5115 with xp2500+ n 6800nu.
OrAnGe said:Now are these people running max settings in their driver sets? Except AA / AF. Cause I am. They aren't fucking with their scores by lowering everything to ass are they.
chuckm1020 said:sounds about right for a x850xt no pe. with my x800xt i get about 5600 marks at stock speeds.
Mav451 said:Lol considering he is running around +100 core/+110( x 2), is it surprising he is turning in numbers very close to GT/Ultra status? I mean 4120/930, I since the bench is still run at 1024, the 256VRAM isn't so much of a factor either.
Dude stop showing off![]()
yah ill do it here in a few minutes. i think it got a little better do to driver changes. i think i ended up getting 5605 at my highest. but ill try again and see what i getmentok1982 said:Are you really getting 5600 now?
The score I have for you is 5,507. Have you got a better score now? Please let me know.![]()
fallguy said:What are your idle temps with your X850's? Just curioous, mine is 39c. Load gets up to 62c running ATitool, and using it to see the temps. Sapphire X850XT/PE here, with stock clocks, and stock cooling.
edit, up to 68c using rthdribl for 15 mins.
