3DMark Vantage Extreme over 8000? HOW?
ElektroDragon
I have an Q9650 OC to 3.2GHz and a stock 4870x2 with 4GB RAM DDR2-1066 at 400FSB. I get a a 3DMark Extreme score of 7328, which is seems to be a correct score. All driver settings are default. I have seen people get over 10K and even over 13K with basically my exact configuration (vista 64, 4870x2, quad core, etc) and similar CPU clock. Of course, a few also score the same and lower than me with my config. Now 3DMark doesn't report the video card clock correctly, but I can't imagine any kind of video overclock that would jump the score from the 7K range to the 10K and 13K range?! So what the heck are these guys doing!? Their CPU score is close to mine, but their GPU score is through the roof!
they could be using 2x 4870 x2 and vantage isnt reporting it or you are just not looking in the right place. besides, its only 3dmark. dont get your panties in an uproar. 3dmark has a vested interest in making you want to get higher scores by having certain configurations, depending on who their sponsors are at a particular point in time. (witness the pricing links next to only certain pieces of hardware for instance) if your "detailed" results have a lot of price links, you can be sure you will be getting a high score. now, if the games you play are getting much lower framerates than other machines with similar spec, that might be a problem.
and oh yea, the above guy is right. they may be cheating it. this has been known to happen 1 or 2 billion times in 3dmark.
