3dmark result question
If this info matters, I just finally unlocked the other 2 cores on my 555 BE and instability under 1.524V. I backed my multiplier down to 18.5 (3712.4 GHz) and it seems to be running stable for now.
3D Mark is just having a problem reading you videocard's info. It could be a driver issue but it has no ill effects with regards to performance results. If you really want to correct it, try a WHQL driver release since they're the ones that Futurmark tests and certifies.
And 1.5xx volts on your CPU seems ridiculously high! I was running a Phenom II X2 550 BE with 4 cores at 1.2v. Check your temps man, and lower that if you can.
I figured it was something to do with the driver
1.36 is stock voltage. I was running 1.4V on my OC and trying to get it stable unlocked but I have it narrowed down to a faulty core.
