3dMark, are these good scores?
carblow12
I got 5196 in 3dMark 03 and 12011 in 3dmark 01'. I am just wodnering if these are good scores. thnx
You just asked the exact same thing like 4 posts down... you dont need 2 of the same thread. people already answered you.
Those are a little low, check to make sure you have agp texture acceleration on. Go to run and type dxdiag then click the display tab to find out. If it's not even available, install the newest chipset drivers for your motherboard.
i got the same 3dmark03 score on 800x600 with my 9500pro :cool: overclocked of course...
This guy does this a lot on this board. I think he is a child...
Is there anything i can do to increase my performance? i have already formated my harddrive and all. In unreal tournament 2003 i get like 40-60 fps at 1280x1024 with full graphics. I thought buying this card would increase my performance. It did but not by what i hoped for. Any suggestions
Well your 3dmark03 score is fine, it's just your 3dmark01 that's a little low. What levels of AA/AF are you using? Do you have Vsync enabled? If you do, I suggest you turn it off unless you just cannot stand or get used to slight texture tearing.
Hmm.. To further increase your performance, I'd re-format the harddrive. And do a fresh install of DOS 5.0. This happens to be the best gaming OS available. After that, Get some *RAGE 3D* drivers.. they happen to work best on a 9800Pro. Trust me.
