3d WorkStation - Not Much To Choose From
lw3d
Hi,
I am in the process to build my own system for 3d use ... basically a workstation ... no games will be played
Since no games will be played I will be sticking to AGP. I will probably be buying a used Quadro in the future. That doesnt leave alot of options for boards at the moment
I am very much leaning towards Intel as of now and the new 6xx series look nice but after reading the reviews and articles I am a bit confused as to whether this chip will work for me
This is the statement that confused me, I got it from xbit ... ' The fresh breed of Pentium 4 processors is intended for infrastructure supporting 800MHz Quad Pumped Bus. Intel Pentium 4 processors 630, 640 and 650 are compatible with mainboards sporting Intel’s 04A Platform Compatibility Guide (PGC), e.g., they have Thermal Design Power (TDP) of 84W; Top-of-the-range Intel Pentium 4 processor model 660 complies to 04B PGC, which means that the chip may have TDP of up to 115W, as previously expected '
Are there any 775 / 865 or 875 boards that will work for me. I know there are some socket 775 / 865 boards out there but do any support 800MHz Quad Pumped Bus. suporting Intel’s 04A Platform Compatibility Guide (PGC) and YDP ... what is TDP
At newegg if you do an avanced search at All Products --> Motherboards - Intel with LGA775 as the CPU SocketType and Intel 865PE as the System Chipset you will find 12 boards ... if you put Intel 875P, you will find one board, the dfi lan party 875P-T which I know broke some oc world records but that doesnt do my situation any good ... will any of these boards work with TDP
Or should I just get a P 4 5xx because there are no AGP boards that support the new P 4 6xx architecture
Thanks and please help guide me
If you use the 865 chipset, even with LGA775 chips, you won't be able to take advantage of the EM64T extentions. I'm not even sure it would work...
If you're going to stay with AGP, I don't see any reason to go to LGA775 unless you want to go up to 3.6 GHz stock instead of 3.4 GHz stock.
All my 0.02 USD, IMO, YMMV, etc.
I just built my wife a system wrapped around the ASUS P4P800-E board. Stable as heck. Very nice board. Intel would be my second choice. I prefer the stability and performance that I get from ASUS Intel boards. :)
So do all 6xx series cpus support 64 bit ... I just thought it was the new extreme edition
If that is the case, it looks like I either better buy now, or expect to buy into a whole new platform
All 6x0 series chips support 64 bit. Only the Extreme Edition will be available on a 1066 bus. There's nothing special about the 6x0 series EE other than clock and bus speed.
I'm building out my 6x0 series (3.2 GHz) computer this weekend. :D
