3D Surround Build - ~$4.2k Budget
Tricky
Mostly Gaming and web with light Photoshop and After Effects work
$4000 to $4500 when everything is said and done (Taxes, shipping, etc)
3) Where do you live?
Arizona
4) What exact parts do you need for that budget?
Case, Mobo, CPU, RAM, GPU x 2, SSD, HHD Storage, PSU, Cooling, Monitor, 3d Vision kit, Sound Card
5) If reusing any parts, what parts will you be reusing?
Blu-Ray drive, keyboard, mouse, steering wheel...wifes checkbook
6) Will you be overclocking?
Yes
24 inch x 3
Build
9) What features do you need in a motherboard?
RAID, SLI, OC, Debug LCD
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, Window 7 64-bit
Before I even start, I'm asking to please not turn this thread into a 3D Surround debate. I know many think it's a gimmick, a fad, a total waste of money...I am aware. I've played it, I loved it and I want it at home everyday and I can afford the expense.
Second, I know AMD is beating nVidia in the GPU market, especially on price point and if AMD had 3D Surround I'd be sure to have it on this list. The only fanboyism you'll find here is to Corsair for their awesome customer support. ;)
I've researched as much as I could on this, but the more eyes the better. My main areas of concern are motherboard (I really don't want to see a mobo fire on this rig), and monitor. Motherboard wise it seems hit or miss no matter who you go with, but I've been nothing but happy with ASUS boards in the past. My monitor worry is really lack of reviews and comparison on the net, I've looked up what I could.
Case:
Corsair Special Edition White Graphite Series 600T: $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139005
Mobo:
ASUS P8P67 DELUXE: $225
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131701
Proc:
Intel Core i7-2600K Sandy Bridge: $314
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
RAM:
CORSAIR XMS3 8GB: $94
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145315
Video:
MSI N580GTX Lightning Xtreme Edition: $600 x 2 = $1200
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127589
SSD:
Crucial M4 CT128M4SSD2 2.5" 128GB - $219
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442
HHD:
Western Digital Caviar Black WD1002FAEX 1TB: $90 x 2: $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
PSU:
Corsair HX1000W: $230
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139007
Cooling:
CORSAIR Hydro H70: $105
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181013
Monitor:
BenQ LCD XL2410T: $300 x 3 = $900
http://shop.benq.us/ProductDetail.aspx?id=261
3d Vision:
NVIDIA 3D Vision: $150
http://www.newegg.com/Product/Product.aspx?Item=N82E16814998052
Sound:
ASUS Xonar Xense: $300
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132018
Looks like a nice build, I might change to the CORSAIR AX1200, it's not that much more (cost wise) and is super efficient (80 Plus Gold rated) (jonnyguru link on the psu http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story2&reid=189)
I'm running the h70 on my 2500k, if they had the h100 out when i got it, I would have jumped on the h100, but the h70 does a good job. Not sure if the 600t has the mount for the h100.
Nice case, if your using the mesh for the side panel you'll prob want to grab a few extra 120mm fans.
