A bit more specifcs are needed here. What's your budget? Do you need super detail? Get a resin printer, which I know very little about.
If you need a standard FDM printer, Bambu are the new standard for "just working" out of the box. Creality are good too, I have an Ender 3 Neo that I'm quite happy with, but it may take some tweaking and learning if you've never used one before. It works much better than a base Ender 3 that I had originally and is a real workhorse. I got mine as a return from ebay several years ago, cost about $100 and it looked like it had only ever been set up once.
It's still a relatively new hobby for me (6-9 months or so) but I have a Creality Ender 3 v3 SE and I'm pretty happy with it as a budget printer (often under $200 new). Was fairly happy with it out of the box though I have upgraded a few things inexpensively (build plate, switched to steel nozzle, have 3D printed some accessories)
That said, without more information about your needs/wants/work, it's difficult to recommend anything specifically.
