3D mockups in maya
trying to model a case mod i wanna make in maya. thing is, i'm having a hard time finsing accurate dimentions for the parts i want. is there a site that has listed parts already made up for use in maya? i've seen case fan mockups in sketch-up, but i'm not using that.
Everfalling said:
alright, cool. so then where do you get those sketchup maockups?
if you need some sketchup components there is a huge thread dedicated to them here, and someones sketchup component site here
good luck
Would anyone know where to get computer components for Autodesk Inventor. Its what I use at work....
Doesn't Inventor import DWG and/or 3DS files?
I don't know of any Inventor specific libraries, but you could always convert the SketchUp files referenced above...
yeah, well, that's what i have and it's what i'm learning. trying to pick up a few instructional videos on solid modeling with NURBS.
