First, here's my system:
E6700 w/stock HS/F
Abit IP35 Pro
2x1 GB Crucial Ballistix Tracers DDR2-800
x1800 Crossfire Card
Maxtor PATA 160gb HD
Tagan GuardianX 1000w PSU
CoolerMaster Mystique Case
The case has one intake 120mm on the front, 1 exhaust 120mm on the back, 1 80mm intake blowing onto the CPU HS/F on the side. Case has good airflow.
I was a little disappointed with my 3DMark 06 score of 4910 when i built this system. I didn't know exactly what to expect, but i did expect more than that. So if figured i'd try a little OC to see if i couldn't get it at least over 5k.
I followed the great guide that is stickied above as i am a complete newbie to overclocking and this is my first attempt. I tried bumping the FSB up to 333 to give a 10x333 multiplier (hope i'm getting the jargon right), and it posted but wouldn't go into windows. So i bumped it down to a modest 300 to give a 10x300 and figured 3.0ghz would be a nice mild overclock for my system.
The RAM is set at a 1:1 ratio. I set the RAM timings at 5-5-5-15 and ran prime 95 for a couple of hours and it worked great. So i put the RAM timings at 4-4-4-12 and ran Prime 95 blend test last night for about 6 hours and it worked great. So i decided that i had a good and stable overclock - so i decided it was time to benchmark again as surely, i was much closer to the 5k mark.
Instead - it came up with 4859 - a drop of 60 points. Needless to say, i'm very disappointed now. Am i doing something wrong? Should the RAM not be set to 1:1 as i think that dropped the speed of the RAM a little from the default the motherboard put it at?
Thanks guys,
Chris
E6700 w/stock HS/F
Abit IP35 Pro
Thanks guys,
Chris
