3d mark problem
pcmaniac
hi ,
When i try to use 3dmark 2001se on my computer it says that directx 8.1 should be installed.by
the way i have direct x 9.0.so i installed directx 8.1, but still the problem persists.
help me!! :mad:
1 are you using hacked video drivers?
2 have you tried reinstalling 3d2001?
3. dx 9.0b again
4. reinstall your mobo drivers
5. reinstall windows from a ghost image and never worry about windows its programs or its horrid registry
There is a patch on the futuremark website that fixes that problem. Depending on what version you have installed, go to the website and look for the patch. It will fix it if that is the problem.
