I am very curious about 3D having been in the electronics store lately and seeing the 50" 3D tv's playing some cartoon blu-rays.
A. They actually look pretty impressive, most likely due to the cartoonish colors and distinct objects which easily can be put on different planes.
B. However, when I checked out another store, they had some more real-life footage. The video of .e.g. an airplane nose as it flew directly toward the user was amazing, but then when they had like real buildings shot on the news and stuff, there was no real depth to it.
I am very interested in 3D now and would love to play BF3 if it were more like the 1st experience. However, I suspect it may not be as distinct considering everythings like a green/brown color without as much distinction between everything.
Then I got around to googling a bunch. It appears there isn't a perfect solution, and you either fiddle around with some manufacturers software to convert to 3D, or there's nvidia 3D. I still have an Nvidia card, but that *may* change and soon.
Monitors of interest. (seem to work with both AMD and Nvidia)
1. I was pretty interested in a passive 3D LG D2342-PN, as it was the cheapest entry into the 3D world. ($ 2XX / euros)
Pros:
It would be great as you only need to maintain 60 FPS, vs. 120 FPS for 120Hz monitors, but then the response time is a quite pathetic 5ms.
Cons:
The glasses are cheap, and without flickering. Then there is also the fact the 3D works with polarization so the pixels are actually only 1920x540 for each eye.
Negative reviews
http://www.youtube.com/watch?v=VWZLzvYED7E&feature=related
http://www.digitalversus.com/lcd-monitor/lg-flatron-d2342-p11721/test.html
This looked decent as far as ghosting.
http://www.mtbs3d.com/phpBB/viewtopic.php?f=116&t=13125&start=15
2. Then I've been reading about the Samsung S23A750 but it's quite expensive. (~$ 4XX / euros)
This looks like a pretty decent screen.
Pros:
Fast, 120Hz / 2ms.
Cons:
Price (almost double the LG)
Doesn't support Nvidia 3D vision so you need other software.
Needs DisplayPort (my current 560 ti doesn't have it, but I am likely going 7970 soon)
I am also wondering if you can watch normal videos/shows etc. that you either stream or have on your PC. Can you watch e.g. .avi / .mpg videos in 3D that are just normal videos? Some screens seem to come with 2D - 3D software, so does it work for normal videos, and if it does, do they look good? Or are you pretty much limited to getting a blu-ray player and buying 3D versions?
It's a pretty bad situation as I have to make a choice, if I might get a HD 7970 then I can't get a Nvidia 3d vision screen, but there are many tradeoffs. I wish I could just try a screen out somewhere but nothing local has any in stock (only tv's). I don't want to tie myself to nvidia. However, the samsung s23a750 requires displayport which I don't have. I currently have a 7970 backordered and it still doesn't have a delivery date and I'm in no hurry to get it anyway as I want to see what happens now that gtx 670 is rumored to come in March. I was hoping to go 3D in the meantime...
So can you watch dvds, mpg/.avi/ streaming videos (e.g. from places like youtube but not necessarily youtube) in 3D? Do they look good if so? How is BF3 in 3D? Does it add much to the game? Is anyone in a similar situation, what have you done about it?
Just to be clear, I'm more interested in playing in 3D then 2D 120 Hz mode. Of course if the 3D sucks I would play in 2D 120Hz, but I don't even want to get a 3D screen if that's the case.
Pros:
Cons:
Negative reviews
Pros:
Fast, 120Hz / 2ms.
Cons:
