3D Aurora 570 Case Modding: Can it be disassembled?
It's riveted together, from my understanding.
You'd have to drill them out, which isn't that complicated of a task.
I just removed the Hard Drive cage from the Gigabyte 3d Aurora, I used a 1/8th inch drill bit and drilled them out, was alot easier than I thought it would be!
As far as putting things back in (I mostly want to change the placement) would be rivets again?
Thanks all
Just replace the rivets you drilled out. It's really quite easy.
