No, V-Ray is not included in Rhino, but none the less there is a plugin available for Rhino. At the time I was modelling this I signed up for the beta program to get free access to the their latest beta version 1.5, plus it helped out that I was a student. Additionally while I was still in Architecture school at the time, the computer lab also had Rhino and V-ray installed on their computers...
You can actually, but with most 3d printers today, you're limited to the size you want and the high cost to print the sucker. If I ever become rich, I do plan on printing this bad boy.
Here's a SS of the the basic 3d model itself and some other renders I did when I was bored. Messed around with some subtle reflective black material with depth of field in one image and a carbon fiber material on the other.
This one only took about 2½ hours, and I'm using 7 year old HP HDX9494NR laptop, so as long as you know how to tweak the settings, you can get really great renderings with little to no hit in quality. The fact that this is a night scene also contributes to the low rendering time, less photons having to be ray traced.
I more than likely won't be able to render up to that resolution without my computer exploding, I can up it in Photoshop if you want? You probably won't notice a difference in pixel density. Lemme know...
Decide to update these to 4k resolution for some of you guys requesting the high res versions so I maxed out the Vray render settings because I got me a new fucking computer and it doesn't take days anymore to get a finished render and did some extra compositing in Photoshop. Be warned they're at least 30-40 megs each, but you want be hard right!
