I have two of these that I found in my garage, does anyone know if they are a smart switch or dummy switch? Or if they are even worth using, I am thinking of wiring my house this winter with Cat5 and will need a switch.
Dude, if it has the word HUB on it, bin them, not worth anything. If it is actually a switch then its age is likely to be rather limited.
Go buy a 16-24 port GbE SWITCH (not a HUB) for under a couple of hundred bucks and while at cabling, use CAT-6. Something tells me that your not into networking in anyway, may be best to get a pro to do the job.
