3930k + RIVE
Status
Not open for further replies.
sakerfalcon
I have no space for this 3930k, so it will have to go. CPU is in excellent condition, never abused, used as a workstation and mildly overclocked at 4.2 to keep it cool and the noise down. It's been paired with the RIVE since its initial use with a D14 on top. This was used as a workstation primarily.
$500 shipped.
Bitspower fittings; add on a few dollars for shipping. Used fittings have the usual scuff marks.
6 x Bitspower Dual Rotary 90 Degree V2 Compression Fitting for 3/8" x 1/2" (BP-MB90R2LCPF-CC2) (5 used, 1 new)
SOLD.
2 x Bitspower Dual Rotary 45 Degree V2 Compression Fitting for 3/8" x 1/2" (BP-MB45R2LCPF-CC2) (used)
$20 for both
1 x Bitspower Deluxe White Case Top Water-Fill Set (BP-DWWP-C04) (new)
$5.
1 x Bitspower Rotary Compression Fitting V2 for 3/8" x 1/2" (BP-MBRCPF-CC2) (new)
$8.
2 x Bitspower Compression Fitting V2 for 3/8" x 1/2" (BP-MBCPF-CC2) (2 new)
$7 / ea (new)
1 x Bitspower COmpression Fitting V2 for 3/8" x 5/8" (BP-MBRCPF-CC3) (used)
$6.
1 x Bitspower Sealing Plug for 3/8" Tube (BP-MBWP-C32) (used)
$4.
Trades I'm looking for: EK Supremacy Evo, Bitspower D-plugs, In-line Thermometer Fittings
http://heatware.com/eval.php?id=70802 32-0-0 thanks!
Status
