I have this one, http://www.newegg.com/Product/Product.aspx?Item=N82E16814202148
It is quiet for sure, but the heat it puts out is massive. I had to turn the case fans up to keep everything cool. It has defeated the purpose of having a quiet card. I may have to add more low speed fans in the future.
So if you had to do it all over again, would you buy the same card?
maybe grab a 970 instead ?
this might help you understand that question
these days the 970 and 390 are not entirely that much different. Power used = heat
^ That's a handly little chart. Is there one for the sapphire card?
