3870X2 Supported
S3th13
Does your motherboard need to support Crossfire/SLI to use this card? or could I stick it into my GA-DS3L and it will run fine with both cores?
System requirements from ATI's site:
* PCI Express® based PC is required with one dual-width X16 lane graphics slot available on the motherboard
* 550 Watt or greater power supply with two 2x3-pin PCIe® power connectors required (750 Watt and four 6-pin connectors for dual ATI CrossFireX™)
* For enhanced performance with ATI Overdrive™1, a power supply with one 2x3-pin and one 2x4-pin PCIe ® power connector is required
* Certified power supplies are strongly recommended
* Certified system cases with good airflow and cooling are recommended
* 1GB of system memory recommended
* Installation software requires CD-ROM drive
* DVD playback requires DVD drive
* Blu-ray™ / HD DVD playback requires a Blu-ray / HD DVD drive
Since it doesn't say it requires anything special I would go ahead and assume it will work with any board.
