3870x2 on nVidia chipset mobo?
AndonSage
Does the HD 3870x2 work on a nVidia chipset motherboard, like a 750i? I figure if the HD 3870x2 does, then an HD 4870x2 will.
@Blackforge: Thanks, that's what I thought, but I wanted to make sure, because someone told me an Intel chipset was needed for a 3870x2. I didn't think they were correct.
@OmegaAvenger: Yep, I knew that. This just had to do with the 3870x2 specifically.
Only need an Intel or AMD based chipset for CrossfireX, which is two of these boards.
See my signature ;)
See my signature ;)
Unless you buy a Dell XPS system, in which case the 790i will also do the trick. :D
