3870X2 Block Question...
MaXXimus
I got the waterblock mounted real nice and was going to install the barbs but Im at a complete loss on a couple things. Instructions show placing an O-Ring on then a spacer and then barb...
1. Two O-Rings are included and I see no mention of where the second one goes... hell... it dont even tell ya which to use with the spacer and barb. One is slightly smaller in diameter and thicker and the other is slightly bigger in diameter and thinner.
2. Does it matter which side I put the barb on? I mean... can I have the barbs on either side depending on the tubing route I want to take or do they HAVE to go on the way the directions show?
