3800+x2 temps
crazymonkee84
So I've been cooling my 3800+x2 with a big typhoon for a few months now. Core 1 is at 37 38C room temp with AS5 and core 2 is around 26 27C. Are those temps pretty much the average or are they a bit hot for a big typhoon?
what vcore are you using? maybe you might think about removing the IHS then you will definitely see a great improvement. otherwise, i think thats about it.
I think my vcore is 1.4v? not completely sure. cpu-z is showing that is fluctuates between 1.4 and 1.45. I don't think I'll be removing the IHS, I just want to know if the temps I have are normal for the fan and proc I have.
