3800 X2 oc/voltage/temp question
bdcarb
In the bios I enabled the vcore overvolt and set the voltage to 1.425. My temps under load are at 44-45C. My voltage through the asus probe is 1.60 :confused: On cpu-z it reads 1.4V. Its prime 95 stable and seems to be working fine. Am I going to fry this proc at that voltage? Which voltage reading is right?
Asus is notorius for having bad temp sensors, I wouldn't sweat it.
