hey guys,
recently got a new system and i seem to be having problems oc'ing it.
system specs:
3800+ x2 am2 2.0ghz
asus m2n-e
ocz gold ddr2 667
stock air
i am able to adjust the fsb or htt, adjust the multi and the volts. also, i can adjust the memory speed from 400, 533, 667, 800. the thing is, when i bring the fsb up to 260 for example, it loads windows but shows a lower clock speed (eg 2200 mhz instead of the 2600-- from 260 x 10 multi).
here is what i did:
put the pcie mhz to 100
set the fsb to 260
changed ram settings to 533 mhz
added some volts (stock 1.35 set to 1.375)
the reason i set the ram to 533 is so that when i up the fsb to 260 the memory will run at 325 (or ddr 650). eventually i would like to get to 270 and run the memory at 337 (which is close to the stock ddr667). when i load up the bios, it shows the fsb at 260, the ram at 533, but when i go into windows, im back to like 2200..
temps where pretty decent on stock air-- in the 40's. anyways, i hope that post made sense.
TIA
system specs:
3800+ x2 am2 2.0ghz
asus m2n-e
ocz gold ddr2 667
stock air
here is what i did:
set the fsb to 260
TIA
