3770K Build, need help!
aviator8
Hi,
I just joined the forum and I'v been going through this build for such a long time now..
And I wanted to share it so I can get the feedback from you guys!
Note that I play battlefield3 and some other games..
Plus that I need the i7 for the Flight Simulator which truly utilize that much of power,
I want to hear from you all regarding the build..
http://pcpartpicker.com/p/Iw3e
Thank you!
Good looking build overall. The things I would change:
Mobo: Stay with Asus but skip the Sabertooth. I have the P67 Sabertooth and it's just not worth the extra dough.
Case: Take a look at the Corsair Carbide 300R. Looks great, matches your other Corsair products, and should be a sure fit for the H100i.
Game on
Answer the sticky at the top otherwise we can't really help all that much.
As Climber noted, please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
