- Feb 8, 2005
Surely this can't be right... Can it?
I'm going to assume it depends on a variety of factors, so I'll expand.drizzt81 said:it depends
Considering that you have a relatively new RAID card and nothing on the PCI bus: yes that score is really low.TeeJayHoward said:I'm going to assume it depends on a variety of factors, so I'll expand.
8x320GB RAID-5 off a HighPoint 2220 in a 32-bit PCI slot on a BFG BFGRNF4U motherboard that's slowly dying, using an Opteron 165 at stock speeds. The array has a single folder on it at the moment with 2.58GB of data inside it. It was initialized via the HighPoint RAID Management software inside of Windows XP x64. At the time of the test, the only other running programs were Windows Messenger and uTorrent, which was writing to a seperate SATA drive on the motherboard's chipset at approximately 200KB/s. There are no other PCI devices installed.
drizzt81 said:Considering that you have a relatively new RAID card and nothing on the PCI bus: yes that score is really low.
Here are some questions:
Is the array initialization complete? (I am sure you have, but asking did not hurt anyone)
How about the CPU utilization?
Did you re-run the test without anything else running?
unhappy_mage said:
New board arrived. DFI LanParty Ultra-D.TeeJayHoward said:Yay. More good news. I just discovered that any data saved on the array gets corrupted. Ugh. I cannot WAIT until my replacement board arrives.
