360 through PC?
Jaffa Cakes!
Hello,
Is there a way to make the audio from my 360 go through my PC to the speakers from the Line-in input?
Thanks
Tom
Don't plug it into your PC's line-in unless it's on and running a program that outputs line-in (like voice recorder).
Plug it directly to your PC's speakers.
I wanted to go through my PC because it would stop me having to unplug/plug in the devices.
Radioshack has what you need.
I can't find it on the website, but go there and tell them what you want.
You probably need a composite to stereo converter cable. It probably costs about 5 dollars.
the VGA cable came with a composite to 2.5mm jack converter so I can plug it into the ports, and I have a converter so I can plug it straight into the speakers, but I wanted to save my self the hassle of unplugging the speakers and plugging them into the 360 etc...
