DeathCloud
- Jul 21, 2005
Can you ise a wireless controller with the play and charge cord on your PC? Everytime I hook it up the device can not be found? Does it have to be the controller made specifically designed for PC?
I got one myself last month, to play Trackmania and NFS. The left thumb joystick from day one tugged to the left, and now every so often simply doesn't register movements, sending me ploughing into walls.
Drivers or hardware? I suspect the latter, but if you all own one, input would be toppo.
I'd say it's likely the pad. You might try re-calibrating it if you can. Mine doesn't work with every game, but it's never had any issues with registering inputs or the analogs being off.
I regularly use mine with fighting game emulators and I find it to work really well in that regard. For aiming in an FPS...I'm no wizard with aiming via a pad, but I find it to be better than a mouse in Bioshock.
Does it have native support, or are you using something like ControlMK?
Gotcha, thanks for the heads up. Any good place to look for the dongle?
