3570k confusion while overclocking
ZrRock
So I have a 3570k I'm trying to overclock on a z77 extreme 4, and I seem to have a stable overclock at 4.3ghz at stock voltage.. Is this normal?
SonDa5
Check your MB BIOS voltage settings to make sure it isn't too high. Should be able to do 4.3GHZ with 1.17v.
reb00tin
You only changed the multiplier?
On my 3570K, I incerased the multiplier from stock 34 (or is it 36?) to 40, everything else is on AUTO. Very stable at 4GHz and the system automatically increased the voltage slightly to 1.18V. So maybe Intel lets you OC and takes care of the voltage for you.
skizzled
On AUTO, it definitely does increase the voltage. But, it may apply too much voltage for a given clock speed/multiplier.
AUTO is great for getting a rough estimate of what your CPU can do but I wouldn't trust it to provide the lowest stable voltage.
reb00tin
I get it. So if I set multiplier to 45 it will set voltage to around 1.2V. How high can I go on AUTO??
skizzled
It really depends on what your set up wants. Like I said, I don't recommend using AUTO but if that's the direction you want to take, go for it. You could always test it out to see what happens.
Blast the multi to 45 and check the voltage while monitoring temperatures as well. I'm not sure anyone really knows what the actual "safe" limit is currently, it's really down to you to decide how far you want to push it.
IntelEnthusiast
Intel Enthusiast Team
I was at 4.3GHz at 1.2v but there may have some more room to play with it and see if I could tune it in at a lower voltage.
