3500 venice OC?
sniper24/7
Im new to OC and i was looking on the forums for an answer to my ?s but i couldnt find any, so here they are. First off i dont want to spend over $50. This said i need all the links you can give me on OC how to's. Next ? is what can i expect to OC the 3500 venice to, i was hoping another 400mhz. Any help is appreciated.
ermm u dont wanna spend more than 50 bucks on what? the actual proc. or cooling?? if coolin, then thats no prob, get an xp-90 with a 92mm fan...as for overclocking...the stock 3500+ is what, 2.2ghz? most people can get 2.6-2.7ghz out of there venices...depends on how high u wanna take ur voltage :p
Eclipse should be the one doing this:
http://www.hardforum.com/showthread.php?t=888001
http://www.hardforum.com/showthread.php?t=795444
Simple, easy, fun, stable when tested, and free (even with a stock cooler). No need to upgrade your current cooler, overclocking is possible even with the stock cooler. No, it won't blow up, fry, or otherwise get damaged unless you run extreme voltage to it (1.75+ on stock cooling imo), or subject it to extreme heat (65-70C). I assume the $50 was for a HSF right? See what it'll do with the stock cooler, then decide on whether or not you even want another HSF, you may be satisfied with the headroom the stock cooler allows.
