3500+ Overclock, Need Some Expert Advise :D
spm_uk
Spec:
3500+ (Winchester)
2GB OCZ Plat 2-3-2-5 Stock
Gigabyte Nforce4 Ultra
Ok i can only get the FSB upto 225 (2421.9mhz) then it craps out.
I raised the CPU voltage from 1.4 to 1.65v to get it this high as well has chaning the memory timings to 2.5-3-2-7. Anyone help me i dont know what else to change to get it any higher |: kinda of new :D
Ive heard things about
Core Voltage
Memory Voltage
and HTT something???
Cheers
did u follow eclipses overclockin guide? usually u wanna overclock in 3 steps...find the max of the motherboard, then the max of the cpu, then the max of the memory and make a combination that can run ur CPU at the highest possible speed
