$350 BC2 upgrade challenge...
I went from a Q6600 @ 3.6Ghz and a GTX 480 to a i7 930 at 4.3Ghz and my framerate almost doubled in BC2. It went from 40-50 to 70-90.
This is at 1920x1200 max settings and in full 32 player servers.
I just upgraded from a Q9550 to an i5 2500K and my BC2 experience went from mediocre-bad to pretty awesome. I wasn't expecting the CPU to make that much difference but apparently it did. I can play in eyefinity 5760x1080 at much much better framerates than i could before. I can turn on 2xAA now and turn some settings to high instead of medium and it still runs better than it did before.
edit * if you scale my res down to 1920x1080 i could always run everything at max settings at great frame rates even with the old cpu.
It is but in this case, his board doesn't support crossfire so that suggestion is moot.
Hardly moot. If it can run a crossfire setup, it can definitely run a single card, can't it?
I do echo the comments of recent posts though. i5s and i7s are noticeably faster in modern games. It's simply a case that for many, the slower performance of a core 2 is still fast enough.
I would think the OP's CPU should hold up pretty well. I have a Phenom II x4 955 running at 3.8 along with the ASUS Matrix 5870 2gb and I get pretty good numbers in BC2 with the following setup:
Frames Time (ms) Min Max Avg
14447 189069 31 97 76.411
Settings:
[WindowSettings]
Width=1920
Height=1080
Fullscreen=true
RefreshRate=60
VSync=false
[Sound]
Quality=medium
VoipEnable=true
SpeakerCount=0
[Graphics]
Effects=high
Soldiers=high
Vehicles=high
Overgrowth=high
Undergrowth=high
StaticObjects=high
Terrain=high
Shadows=high
Bloom=true
HSAO=false
MSAA=3
Water=high
MainQuality=custom
Texture=high
DxVersion=auto
Aniso=4
Detail=high
RenderAheadLimit=2
Fov=90
I thought the Core 2 Quads were fairly close to the Phenom II's in performance.
Never got close to that performance level. I am going to make the next build a games only pc. No programs except for games. No internet browsing at all. Going to use this crappy dell for everything else. Going to get the fastest gpu I can afford soon. Then start saving up for a new cpu/mobo/ram/psu.
I think one of the issues I had was my HD was chopped up and packed with crap. Need to keep it clean.
In general terms, a 3.8Ghz Phenom II is about a 3.3-3.4Ghz Core 2 Quad (45nm). People argue they're faster in games than that but results seem pretty varied about such things.
