Etherton
Will Bang for Poof
- Aug 7, 2006
Sorry, details would help!
I'm using GTX 780 SLI on my desktop with the displayport connector.
What happens is the screen starts to go to power save mode, but then immediately wakes itself back up with some message about no connection being present. It does this over and over until you wiggle the mouse or whatever to tell Windows to turn the screen back on.
It's fine if you shut the computer down completely. I work around it by doing that and using a screensaver. It's just odd that my Macbook Retina works fine (also has an Nvidia card in it, but uses TB).
If you search this thread it was a pretty common problem. Odd thing is, when I had my first 34UM95 (before I got the 94 for cheaper with a longer warranty), I don't remember the sleep issue being present.
I just got it today. No issues here going into power save/sleep modes. Running SLI 780Ti Kingpin's with the latest drivers.
