- Oct 7, 2000
forget the system, get your housing sorted first.
I think he's been told this plenty of times before and yet persists in his debasement of sensibility.forget the system, get your housing sorted first.
Is this the one with the coal furnace?So i talked today with my real estate sale advisor. And he talked that there is customer really interested to buy my house. So i think i will sell fast my current house. Then buy cheaper house in smaller village. Then PC.
No other. , without coal furnace, i m currently selling : )Is this the one with the coal furnace?
games 1440P
All of those are shovelware except obs.Well I can tell you this... depending on what games.. today, my rig in my sig - uses 40% of 64gb with
Warzone, discord, chatty, streamlabs obs, logitech ghub, corsair icue, xbox chat going...
so I will say 64gb minimum. my opinion... as I have not experienced DDR5 yet and also was intrigued by the different sizes now.
I've had 64GB since 2015 and I never see it all used outside of work or when using ram drives.I've been running 64GB and don't think I've ever seen it much over 20GB used with all my common apps/services running while gaming. The only reason I have it is it was a good deal in FS/FT and was relatively cheap. So unless you're doing any other productivity stuff with it, I think it'd be hard to exceed 32GB usage with most games and normal app/browser usage.
This. Just suck it up and get 2 x 32 and you are good for years and years.I'm not going to comment on the OP's sincerity or lack thereof here, but IMO 64 is where it's at if you're not on a tight budget, especially if you're a heavy multitasker. If you're gaming most of the time and are conscientious about closing unused programs (or just restart your computer frequently), 32 is okay, though. But IMO what's the point? Unless the next set of Ryzen boards/firmware make it a lot easier to run 4 sticks at full speed, you only get 2 sticks. If you get 32GB and then down the line you find out that you need more, those 32GBs are not an investment... they're just e-waste now unless you build another computer with them. You could sell them, but that's a lot of effort and you won't recoup full cost. So these days most of my computers (aside from my laptop, which I upgraded to 32GB and is primarily focused on nothing but gaming and is rebooted frequently), I throw in 64. With 64 you just never have to worry, at least probably not for 10+ years.
I kind of did get lucky with my sticks, though. I got them for half price open box from Microcenter and they're a nice pair of Hynix M-dies.
Get 32GB 6000 CL30 sweet spot memory now, and upgrade to 64GB when Zen 6 comes.32GB is fine. 48+ is wasteful for a gaming machine today but decide if it's worth the extra $. Knowing you're probably good on RAM until the machine is obsolete is worth something. 64 GB will last until DDR6 and new platforms are knocking on the door.
for 9800x3d?2 x 24GB @ 6000 CL30/28 is the sweet spot for speed & capacity given they are single rank.
