sadbuttrue
- Feb 16, 2008
I'm slowly going through every 32" 1080p panel out there, making full use of the DSA for online purchases here in the UK. Eventually I hope to find one worth keeping, but so far I'm less than impressed
Samsung 5 series
Latest models use a cheap chinese panel and have severe ghosting. It's so bad you can see green trails behind anything that moves. The metallic glow of whites also make it unpleasant to use for text.
Panasonic 8 series European models
Ghosting is minimal. Non-defeatable edge enhancement and inability to display coloured text make this the worst TFT I've seen for PC use.
LG 7000 series
This is a VA panel (I believe the larger screens are IPS tho). The ghosting is on a par with the Panasonic, with much better blacks due to panel type. However, it suffers from a similar coloured text issue. Reds have a yellow tinge and yellows are almost white. Identical to the issue mentioned here for an old Westinghouse TX42.
On further examination, the problem applies to blue text on dark background too. It is identical to the Panasonic, so possibly using the same processing chip.
Feel free to add any other models you've come across and consider equally useless.
Next up: Toshiba XV or RV
Samsung 5 series
LG 7000 series
