30s & 50s on Hyper 212+
So last night I switch out the ASUS p8p67 Pro for a new one rev b3 (revised for Intel Recall). Because of the switch, I also put in a Coolermaster Hyper 212+ in a dual 120mm fans in a push-pull configuration. I ran Prime95 for about 30 minutes and i am consistently getting mid 50s (53-55c) temps. The TJ Max is about the low 40s (40-43c). At idle, the cpu temp is 30-31. Is this a decent temperature? Still running stock right now. Just want to see that I am getting assurance that i'm getting stable and decent temps before going OC'ing.
I think the CM H212+ is out performed by nearly every other cooler. it's really a budget solution and slightly better then stock...
