3090 in Silverstone FT01
Blackstone
Does anyone know if a single founders edition RTX 3090 will fit in a FT01 chassis? I have the top drive bay removed to accommodate my 1080ti, but the 3090 is longer and WIDER, I believe.
We all have the same information you do that's available to everyone, however you have the case in front of you so you're in the best position to find out.
Dimensions straight from Nvidia.com
Length 12.3" (313 mm)
Width 5.4" (138 mm)
Get out that tape measure!
Alright, you win. Out of curiosity I looked around and the FT01 site has a section on this. Length looks fine, now width above the PCIe bracket I can't tell from this picture but you should be able to see pretty quickly with the case in front of you.
Does anyone know if a 3090 FE will fit in the bottom PCIe slot with only the top drive cage removed?
Perfect fit! Even in the bottom slot. FT01 still going strong.
Please no cable routing comments please, this case has no window, I have no time and the PC was assembled by Jawas.
