Hey,
I'm having a pretty peculiar problem with my 3007wfp. I just got it used and at the time I only had a single-dvi cable to test it with. Predictably, this only supported up to 1280x800 but besides that it worked fine.
I just got a dvi-d dual link to test it with and 2560 x 1600 works but the image is extremely grainy. It has large scan lines, and appeared with a green layer/filter for a little while. Even at 1280x800 the image is still grainy/green. I tried switching it out for the single link and the color was fine again.
Would this be an image with the cable or the monitor? The cable I got was http://www.amazon.com/Cables-Unlimi...W9WM/ref=sr_1_8?ie=UTF8&qid=1318556360&sr=8-8
thanks!
thanks!
