3000+ benchmarking lower than a 2.8 p4???
st4rk
I benched my barton 3000+ in pcmark2002. Got 6500 for cpu. At work I benched a 2.8 and it got 6900, and a 3.0 got 7300.
(I wanted to bench our dual xeon 15k scsi 2gb ram servers, but they needed directx updated, and since they are production I cannot restart them :p.)
Anyone here have a 2500+ or 3000+ that they have benchmarked in pcmark2002? Could you tell me what you got for cpu and memory?
Thanks.
http://www.hardocp.com/article.html?art=NDI2
http://www.anandtech.com/cpu/showdoc.html?i=1783
http://www.lostcircuits.com/cpu/amd_xp3000+/4.shtml
PCMark is a pretty poor artificial benchmark, generally. None of the three reviews of the Barton 3000+ above used it, for example. But there are plenty of numbers in those articles for you to compare your system to.
But! Don't forget that the performance of your CPU is also largely affected by the performance of the other components in your system. You *cannot* compare benchmarking results between two systems unless as many components as possible are identical (obviously, the motherboard can't be, for AMD vs Intel comparisons...)
It is a synthetic benchmark, and not very accurate all the time, but my generaly opinion and from what I've seen, a 2.8C would surpass the AthlonXP Barton 3000+ in just about any test. A64, probably not...but the Barton core isn't standing up too well (in performance only) to the C class P4s.
