Vulcanworlds
- Aug 28, 2005
ok so that's basically it. im still unsure of what cpu to get 3000+,3200+ or 3500+. i would like a 3500+ but if i drop down to the 3200+ i could use that money.(30 bucks) for something else(xp-90 or towards other stuff) if i go all the way down to the 3000+ it will save around 75 bucks but it does seem like a pretty big change(to me at least) 400mhz
so i will be using the DFI NDAG s939 board. that or the chaintech vnf4/ultra board. both seem like great boards and i still havent decided.
for ram im keeping it cheap around the 90 dollar max range. (2x512mb) so it will probably be value ram.
i will probably be on the stock heatsink for a while and maybe go to the xp-90 later on. which do you think will be the best for me? im really thinking the 3200+ and oc to like 2.4 or 2.5 hopefully.
