$300 to upgrade
nxcess
I'm trying to help my lil bro upgrade his computer. Only thing I'll be keeping from his computer is the case, psu, 80 gig harddrive, 1 stick 512mb ddr333 ram, and radeon 9600 pro. I've been out of the computer loop for a while so I need a lil help finding good deals on parts. 300 isn't enough to upgrade to the newest thing but anything is better than what he has now.
What I need to get is an AMD processer. Looking at either getting a socket 754 or 939. L2 cache needs to be 512k or higher. Mobo doesn't matter. As long as it uses the Nvidia chipset and is slightly overclockable. I'm okay with it. Doesn't need to be DFI or Asus. Something like that would be overkill for him. And another stick of 512 ddr333.
Anyone know of good deals where I can get these from. It can be used or new. I only got 300 to upgrade. If a processor is moddable. I would like to know. Same goes for the motherboard.
Cpu & motherboard Combo 123.99
BIOSTAR TForce6100-939 Socket 939 NVIDIA GeForce 6100 Micro ATX AMD
Motherboard - Retail
Item #: N82E16813138264
AMD Athlon 64 3200+ Venice 2.0GHz Socket 939 Processor Model ADA3200BPBOX - Retail
Item #: N82E16819103535
I would add 1gb of ram (DDR 400+) (or a matching 512) to this,
and the Pci-e video card of your choice. Lets say you do get this combo. Add 512mb matching ram 55.00 (173.99 total) add a new HD (43.00 total 218.00) and a 512 mb video card 88.00 (300.00 total) . In a few months you can go X2 4400 (or more).:D
Agp is gone in the performance markets of motherboards. This is going to be better.
For that price. That's a good setup. How about a mobo w/o a video card? That way I can put the money towards a pci-e video card.
You should be able to do better than a single core venice 3200 for that price.
$320 w/ SLI - ALL BRAND NEW MOBO + CPU
Opteron 165 (Free 3 Day Shipping!) :) $154
http://www.newegg.com/Product/Product.asp?Item=N82E16819103588
Foxconn NF4SK8AA-8KRS s939 nForce4 SLI Motherboard $65 (after rebate)
http://www.newegg.com/Product/Product.asp?Item=N82E16813186059
The Opteron is dual core, and will overclock to the mid 2.XGhz on air cooling. A veritable beast of a setup for very short money, plus the abiltiy to go SLI and extend the life of the graphics capability. It's a great time to upgrade 939 on a budget with these opterons, but it won't last, as 939 is offically EOL.
is the 9800pro AGP or PCIe? Forgive me, i'm an NVidia user.
zv
9600 is agp, i checked
I was also doing a total system, not just mobo processor, Vc
I liked the way gwarren007 picked out good parts for 300. Motherboard, cpu, plus ram and maybe a video pci-e video card. This computer isn't for my but my lil brother. He doesn't require much. Only enought to play Counter-Strike.
