G5 plus for $250-300. Hell, I put it towards the high end right now, the bang for the buck on that phone is incredible.
Also: used Galaxy S7, OnePlus 3T, HTC 10.
was really looking at the moto z2 play right now they gimped it vwz only...
Why is it that folks seem to automatically jump to a conclusion like the one made above about battery capacity and battery life, automagically? Just because the previous generation had a slightly higher capacity battery than the new model does not mean an automatic reduction in overall run time per charge. Newer SoCs come out all the time, they are almost always better than the previous generation in terms of battery usage, power efficiency, and performance not to mention that other aspects of the overall hardware improve in terms of power efficiency as well and the mobile OS itself gains improvements to stretch battery life too.
And don't forget just because LCD technology has been around for oh, 40+ years now, that doesn't mean it's still not improving in terms of power efficiency for the panels as well as having LED backlit ones as well which also improve in terms of that battery sipping efficiency.
I would bet you money (not much, being retired and not independently wealthy does have limits) that the newer model of the Moto Z Play will last longer on a charge than the previous generation did if you could compare a brand new model of each fresh from the boxes and on their first charges, and the newer model would consistently get better battery life per charge as time passed.
Anyway, not meaning to rag or rant but that always gets me when people do that, seems like maybe folks should get one of these and make use of it.
Cases are mandatory . I did have a tempered glass screen protector on it that broke last time i was butterfingers. Ordered a new one and it kept vanishing from my porch due a thief. If you have anything delivered to your house make sure you opt into text notifications
