Here are my system specs if it helps
-Athlon 64 3500
-1 gig ocz rev 2 at 2-2-2-5
-520 watt vantec powerseupply
-2 optical drives
-BFG 6800 ultra oc.
-2 western digital raptors (74 gigs)
-1 Maxtor Diamond Max 3 (300 gigs)
-Audigy ZS
-MSI K8N Neo 2 platinum nforce 3
I would just like to point out that at the moment I am using one of the raptors as a sotrage drive untill I get the Diamond Max3 working properly. (that raptors are not in Raid 0) The raptor without the operating system has a 4gb partition for the swap file and the rest is storage. The raptors are on sata 3 and 4 (because People had problems with them on 1 and 2 with raid 0 when overclocking) The diamond max is on sata 1.
Anyways on to my problem. I just bought the Diamond Max 3 hard drive today. Upon booting up the machine And inserting the windws xp installation disk so I could partition the hard drive 3 times I noticed it only had 127 gigs of storage on it. I then went to the website to check that I had infact bought the correct drive. Everything matched up. I thent went and formatted and installed windows xp pro but still only 127 gigs.
Does anyone know what the problem is?
I am going to try updating my bios and see if that fixes it.
I have heard something about wrong firmwares or something along those lines with hard drives. Is there a way to check firmware versions?
-Athlon 64 3500
-2 optical drives
-BFG 6800 ultra oc.
-Audigy ZS
