300 GB Seagate 8 Mb Buffer UATA $119 AR
There is a thread I started last week friday about this, I bit and bought 2. Should have gone for more, but, my tower is full:(
i mite buy this and use my PATA to SATA converter on it. even though i have ample space now
They had sata's on sale last week, 300gb, they where 149$ after rebate. I camp outpost a lot, I have gotten quite a few deals there.
awesome deal.
i was thinking about building a terabyte file server from four 250gb drives from a previous thread.
but after seeing this deal, i realized that the only thing better than a terabyte server is a 1.2 terabyte server :)
/puts geeky-ness into full throttle
Seagate drives rock, 5 year warranty, you can't beat that! I don't bother buying anything else, anymore!
I got one but it's pretty bad... I dunno, it's fairly slow and kinda noisy (frequent clicks and some scraping sounds) :D Also runs fairly hot :( U get what u pay for ;)
:eek:
That's not good and not normal for Seagate. I own five 200 GB Seagate drives and I've never heard anything above the lightest pattering, barely audible above my caes fans. They do, as all quiet drives, run fairly hot howerver so that's normal. They're not creating more heat though they just have sound insulating materials which also insulate heat quiet nicely.
If you're really hearing "scraping" sounds that's extremely bad and your drive's probably failing. Backup your data and run a SMART check in your BIOS. If it continues sounding abnormal or anything comes up in the SMART check send it in for warranty service / replacement.
Hvatum said:
:eek:
My case is pretty quiet, I have watercooling and all fans on low voltage so I hear HDs fairly clearly. If u do own the 7200.8s, they might be producing loads of seek noise u don't hear over the fans unless u quitened them as well...
All of my seagate drives are really quiet. Never a noise from them other then the hard drive grind during massive read/writes, but, it is hardly noticable.
I'm running Panaflo fans at low voltage. Maybe my case foam dampens some of the noises that you're hearing.
