30 LCD yellow tint
Firewall
I need some suggestions on what I can do. I have a powerspec 30 inch lcd that I use as a tv/monitor. It works fine when I use it with a DVI connection for my PC, and it works fine when I use the cable wire from my PVR for my tv. Also, the CV connections that hook up my xbox 360 work awesome as well.
The problem is, when I don't use the actual cable from my PVR and I use the yellow, red, and white connectors. The tv gets this dark yellowish tint to it that I can't seem to get rid of.
I tried adjusting the color, brightness, saturation, background lighting, just about every option it gives me.
Anyone else heard of anything like this?
Do you have any other component outputs (red white and green) to test if the PVR might be having a problem with it's component out? If you get the chance to test something else out and the TV still has the same problem then it's component processing is shot.
