3 WU's finished, 0 points gained ?
Possible I guess, strange that I get three of them in one day and I have not ever noticed it before. I only have around 10 folders right now.
I don't know which computer they are coming from. There are a couple slow ass systems I have installed F@H on, maybe it was from that.
Some people have access to the data to give you a reference IP and type of boxen. They will be able to help on your search.
if you have some slow ass machines maybe you missed the dead line?
FOR THE HORDE
There's no way I can check.. the slower comps I have installed it on are not even mine, and I don't want to bug the people who own them. It just seems weird that this would happen three times in one day. Maybe it has happened before but I didn't notice because they were mixed in with other WU's that gave points.
When it rains, it pours. I've seen computers (not mine, thank goodness) that will spit out a couple hundred early_unit_ends per day. It does nasty things to the [H] vs. Roo charts. You probably just have one machine that's misbehaving. Good luck finding it!
You might want to pop over to the www.folding-community.org forums and mention it there, they should be able to at least narrow it down to CPU architecture and hopefully helping you narrow your search.
It's pretty limited what info I have access to, but I can tell you it seems to be 2 machines having problems.
CPUid IP Address team cpu type cpu species os type os species Last credit Last returned WU Proj Run Clone Gen
2687D2AC21XXXXXXB1 XX.XX.XX.97 33 x86 Athlon Windows XP 0 2006-04-03 12:10:25 2094 169 39 3
216F79034CXXXXXXC9 XX.XX.XX.182 33 x86 Athlon Windows XP 0 2006-04-04 02:12:14 2108 56 15 3
ChelseaOilman
Chelsea to the rescue!
Congrats on hitting 2Mil! Awesome accomplishment!
:D
see, those pesky AMD's causing all the trouble again... :D
