3 short beeps then a normal beep
Hi all new here just built a new cpu not the greatest but decent anyway the mobo is a socket 1155 MSI H67MA-E35. When I start up the cpu there's 3 short fast beeps and then a normal one? Once I start cpu works fine besides those beeps any Ideas what it could be or any have beep codes for it?
Core I5 2500 3.3ghz
Corsair 80+ 650w PS
Evga Gtx 570 HD
2x2gig sticks DDR3 ram 1333 ripsaw
Did you try without the graphics adapter? The board can use the CPU-integrated GPU, you can try this first. You can disable the "fancy" boot screen and look if the plain-text screen displays any errors.
The beep codes are dependent on the BIOS vendor. I've seen boards that signal 1x long, 3x short for a graphics adapter error, but not the other way around.
Yeah I already reset the gfx card and memory modules still does it. Guess well just be happy for now cause all runs ok still boots to windows 7 64 bit thanks all. Just a little worried down the road of something failing.
