techpriest
- Feb 22, 2008
Hey guys, got 3 questions, sorry for the noobness:
1. Can someone tell me which is the correct fsb strap setting for 1:1?
On auto the dram freq option is ddr2-801. On 400mhz fsbstrap it is ddr2-800.
2. I want to stay at 3.6ghz 1:1fsb/dram, what should I do next? Lower performance level and run memtest and/or prime?
3. Pci-e freq: 101 or 100? Not really sure anymore.
system:
Asus P5Q Pro / E8400 @ 3600MHz
2x2 GB G.skill DDR2-800 5-5-5-15
Evga 8800GTS 512mb / x-fi xtreme gamer
WD 640GB
Antec Neohe 500w
Vista business x64
current settings: [24hrs prime blend stable/12hrsmemtest stable]
system:
WD 640GB
Antec Neohe 500w
Vista business x64
Code:
JumperFree Configuration Settings
AI Overclock tuner: MANUAL
CPU Ratio Setting: AUTO
FSB Strap to North Bridge: AUTO
FSB Frequency: 400
PCI-E Frequency: 101
DRAM Frequency: DDR2-801
DRAM Timing Control: MANUAL
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
DRAM Static Read Control: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: DISABLED
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
Performance Level: 13
CPU Voltage: 1.25625v (CPU-Z readings - idle: 1.232V - load: 1.240V)
CPU GTL Voltage Reference: AUTO
CPU PLL Voltage: AUTO
FSB Termination Voltage: AUTO
DRAM Voltage: AUTO (gskill 2x2gb ram rated at 1.8-1.9)
NB Voltage: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: AUTO
CPU Spread Spectrum: DISABLED
PCIE Spread Spectrum: DISABLED
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
Advance CPU Settings
C1E Suppport: ENABLED
Max CPUID Value Limit: DISABLED
Intel® Virtualization Tech: DISABLED
CPU TM Function: ENABLED
Execute Disable Bit: ENABLED
Intel SpeedStep Technology: DISABLED
